is it easy to replace the stator by myself?
M
maddog21
a guy at the shop said it will cost me about $500 or $600 to replace it plus labor. I dont think the stator is too much money, or how long it will take. have anyone done it before? looking any way to save my $$$$$. a new one worth about 200 or less? any help or information would be good.
its 2000 rmk 700
its not hard to replace give me a call if you want 715-305-7177 . you will neeed a puller for the fly wheel i use a three bolt puller . outher than that normal hand tools will get it done.
I have s used stator if you are interested. you should beable to do it in the sled, mostly 10mm bolts except the flywheel you will need a puller. pm me if interested in the stator
ok thanks.
i would have to wait for the snow so i can ride it on and see if it running longer. all they put the new sparks in it.
its 2000 rmk 700
Stator testing out of a sled
http://www.youtube.com/watch?v=rCqojU5wHos
Stator testing in a sled:
http://www.youtube.com/watch?v=Uzz2NZiw3fk
Stator removal:
http://www.youtube.com/watch?v=eGSsyRRiIDI
Stator reinstall:
http://www.youtube.com/watch?v=qGiXzdF_IaU
Testing a pulser/Trigger coil
http://www.youtube.com/watch?v=ed8jEy3jL0U
thanks! think it will help.. but my sled is polaris.. are they all same?
All 2 strokes are very similar. My videos will get you 95% or more of the info you need to do it yourself although on some models you can change the timing through a slotted Flywheel so make sure you mark where everything is located when you take it apart.
There are a couple on E-Bay that can rebuild your stator for yah. Just remember when installing stator, to line up the triangle marks on stator plate and on water pump housing cover, as this is your timing.
