Is eVent giving Goretex and Klim something to worry about?
"The pores in the membrane get clogged with oil off your skin along with sled oil dirt and other microdebris. If your GoreTex or eVent garment has lost its waterproof/breathability over time chances are the membrane is just clogged. Check out NixWax Tech Wash. It will revive that membrane and make it feel like a brand new coat."
eVent 'Cleans" out much better than Gore and isn't as fragile with oils and comtamination.
I have one of the Event jackets that came with my Polaris Dragon. I wear the Walmart under garments and have never been cold or wet, even while riding in -30C, after 3 years use it still looks and works like new.
I just wanted to add in my experience with Gore-tex. I bought a North Face jacket about 7 years ago... 3-ply Gore-tex shell.... I'm not exactly easy on my clothes... I expect to replace a jacket every few years... Anyway after wearing the jacket for the last 7 years, it still looks like new and holds up to the elements pretty well, although I find that on really wet days it leaks a little. I am going with Klim gear this year because of my experience with Gore-tex and the fact that their gear is taylored to sledders. I just wish they had a little better selection for women.... That's on it's way... So I've been told!
:cheer2:
lifetime warranty on your north face jacket...wash it. send it back and they will water test it.. if it leaks you will get a new jacket no questions asked. sickest warranty I have ever seen..
Sorry if I missed it in the above posts but any idea how eVent compares in price to Klim? I know my comfort shouldn't have a price tag but if I can equally comfortable and dry for $600 instead of $1000 I'm in.:smow:
Looks interesting. I wear good breathable base layer underwear and the moisture definitely does wick away from the body but it gets as far as the liner of my supposedly breathable jacket and stops there. The liner gets and stays soaked until I take the jacket off and dry it out. This is an interesting demo I found when I Googled eVent. I assume they're comparing eVent to Goretex.
http://www.youtube.com/watch?v=yi0DaHQ5ro4&feature=related
This is impressive in a "laboratory setting", but who really has air pressure inside their jacket or pants (unless they ate baked beans for breakfast)? :D
My experience with Event was this: when my bibs started to leak in the rear after 2 seasons, i took them back to the place i got them and was told "sorry they only have a 1 year warranty"....yikes!! And i paid $25 less for them than a good pair of Klim bibs. Needless to say...i bought me a pair of Klim to replace them and have no plans to ever own another Event product until they have a better warranty.
"eVent 'Cleans" out much better than Gore and isn't as fragile with oils and comtamination. "
Is there any research behind this or was this what Bud over at Snowshow X said in his booth?
Here's kinda how eVent works different:
A PTFE (eVent and gore), in its natural state, is readily contaminated with oils from our body and other environmental substances. The oil contamination eliminates the hydrophobic quality and the fabrics leak.
To solve this, some manufacturers (gore)put a layer of polyurethane (PU) over the PTFE membrane to protect it from contamination. The PU is hydrophilic; it absorbs water. First, sweat is condensed and absorbed into the PU layer on the inside of the fabric. Because PU absorbs and retains sweat, the inside of the fabric becomes wet. Then, body heat begins to push that dampness through to the outside of the fabric where it can finally evaporate - a very inefficient process. This combination “breathes” but not nearly as efficiently as the PTFE membrane alone.
Voila! Along comes eVent fabrics. They have developed a way to make oleophobic (oil repelling) while still retaining the hydrophobic (water repelling) characteristics of PTFE. It keeps outside water out and lets the inside sweat pass right through it. Where Gore and others collect it and NOT let it pass through through direct venting.
Now we have a material,eVent, that is very waterproof, combined with one of the highest breathability ratings of any WP/B fabric! Tests run at the US Army’s Soldier Systems Center, in Natick, Massachusetts, put eVent fabric at the very top of over a dozen fabrics sampled.
eVENT Fabric is an ePTFE film that has been rendered oil-repellant, and thereby free from body-oil contamination, via a method that retains both the inherent open-pore structure of the membrane as well as its hydrophobic properties.
eVent does not add a second layer of Polyurethane like Goretex. eVent Teflon membrane is treated through a propritary (patented) process of coating the ACTUAL INDIVIDUAL MICROSCOPIC FIBERS WITHIN THE MEMBRANE to prevent contamination by skin oils or sunscreen. This propriatary coating does not inhibit vapor passage away from the garment wearer like the polyurethane coating that Goretex uses.
......i totally copy and pasted this off the internet. It was way to much to type much less what you have now read!
I wonder if this is what the newer version of Goretex "XCR" is? Kilm uses XCR in the most expensive products and standard goretex in others. I believe Gore came out with XCR to improve beathablity. However XCR may still not be in the same league as eVent.
XCR isn't even close. None of them really close to eVent.
all i know is my event that came with my 08 d8 has never let me down, also found out that if u r under the sled with the gas cap leaking on your leg it will melt the material in the bibs, coat good though
