What does this do for you? Going to a 19t? Iam curious on what this helps when your running a turbo??
If you have the horsepower and your engine is pulling the proper rpm why would you want to gear down. That will slow down your track speed. And it is the high track speeds that allow the turbos to go so high. Just wondering myself is all I am saying.
for shootin the steep...you prob dont wanna gear down then..
but not everyone is riding the steep!
don,t go lower than 19 tooth with a turbo, not enough metal left and you will break the gear
18 tooth, YIKES, that a disaster.
So has anyone actually seen a broken 18 tooth gear? Or is this an old wives tale? I mean, it is a Yamaha part, you would think that they would have thought about the engineering aspect of the gear when designing it.
Has anyone broken any top gear, period?
Just curious...
Oh, I am N/A....
I have one broken 18 at home. Not in piece, but shaved the top of the tooth. Tension on chain must be PERFECT, even without a Turbo. And the bad thing, both chain and gear are scrap after that.
Running a good tension, but 162 x 16 x 2.5, and 500 km after, everything broken
I wish we could put a 42 bottom gear in the nytro.
