Here is the ? is lighter better. Windy day on icey road which trailer will stay on the road.
The only people that benifit from aluminum trailers are truckers who can haul more goods with the weight savings of an aluminum trailer. You will never see a difference between a steel and aluminum trailer as far a MPG goes.
I disagree, respectfully of course, While that may well be a nearly true statement for the flat landers, ( on the flat you will still see a difference just not as pronounced) common sense would tell you it is easier to pull 2000 #'s (Aluminum Trailer) up a mountain pass than say 2500 #'s (Steel Trailer) up the same pass. So over the life of the trailer you will make up the cost difference in fuel economy, not to mention wear parts. It is much easier on your brakes and transmission to slow and stop a 2000 #'s (Aluminum Trailer) coming down a mountain pass than say 2500 #'s (Steel Trailer) down the same pass.
Over the life of the trailer it will save you money by buying the lighter, well built Aluminum Trailer. I must stress the well built part because not all the manufactures welds are worth the premium they want to charge for the aluminum.
I disagree completely, but am curious of your source?
500lbs is nothing for today's vehicles, unless you're towing with a Yugo. Even at 1000lbs, I can't see the difference paying for itself like stated.
Make sure you get the scale net weight of the trailer you are buying if your goal is to get a light trailer. Big differences. A Triton 24' aluminum trailer is much lighter than a Featherlite of the same size. I wanted a really nice light weight trailer to haul my 4 sled. Ended up with a tricked out 24' Featherlite, started with a 22' steel Mirage. Both of those trailers are about the same weight. The Featherlite is loaded up with Furnace, fuel rig, cabinets, bed/benches so it is actually heavier than the stripped out Mirage. Scale weight is listed right at 4000lbs for the Feather, a little less for the Mirage if you can believe it. Probably weighs 4600-4700 empty with all the extras. A Triton is like 2800lbs striped. That trailer tows nice though, I really like it. Especially with all the add ons.
