removed back side of clutch via 6 screws, instructions say slide off rear sheave then remove spring. helix won't come apart . removed 3 screws on front but having trouble unscrewing center part has holes drilled in it seems to be pretty tight and hard to stop from turning, using large slip joint pliers to unscrew center piece. do not wan to screw things up. please help thank u jeff
