Is there a way to get the oil pump set on the bench with this cable? I have the throttle bodies installed and the cable all hooked up with a little bit of pull figured in for idle and both of the adjusters are all the way out a I still don't have enough to get the lines set on the oil pump, I'm sure not having the throttle block hooked up is screwing me up but I didn't get any directions and I know there was a DVD floating around somewhere with instructions. I'd rather not have to set the oil pump once I get the engine installed.
