installing cr tunnel
H
hotliner23
New member
anyone out there install a cr 162 tunnel? can it be done at home or do I need special tools and how hard is it? its going on a 09 nytro i am changing out track, drivers and skid so i figured since its all tore apart i will change that out to if its not to tuff.
I installed a CR 162 tunnel on my 08 nytro last summer in my garage. It was the easiest tunnel I've done. There is not a large overlap between the tunnel and bulkhead, so there's not a ton of rivets to remove. I would recommend a pneumatic rivet gun. The CR tunnel fits very nice and has pre-drilled holes to help you get things started. Just make sure that the tunnel is square with the bulkhead before you start attaching it. It is really pretty easy.
