You should RPM lower after adding the shift assist with out any other change. Most all sleds do. You can see how with out it how the shift was hanging up. With the shift assist the secondary will shift up more loading the motor more.
Don.
I just put a Shift assist in my M & installed the gold spring in the primary & orange in the secondary. Engagement is really low RPM's. I like it personally.
What is the spring rate of the new primary spring? My guess is the rate is lower on the start. Like from a 135 down to a 120 or something.
Shift assist and secondary will have no affect on engagement.
Thunder
That seems to be the consensus, but for some reason with only the shift assist changed out I gained about 100-150 rpm.![]()
Hey Dono, could you post some pics of the opened up primary?
I'm seeing paint missing on my spring, but there are no machine shops around here who have a clue about doing this.
Could someone do a more crude approach with a die grinder maybe?
Nevermind. Just saw the pics on the link you added. Doesn't look like die-grinder territory to me.
Would there still be a big gain to be had in the primary using just the friction shims and not opening up the spring pocket?
Also would using those to pre-load the primary compensate for the RPM drop the shift assist will create from the secondary?
Make sure you don't get to many shims. If you do you will run out of spring travel and coil bind the spring before the primary closes up all the way.
Also I have noticed the titanium springs are a lot thicker wire, and appear to be a bit bigger in the OD than a standard steel spring. So they could bind up even more.
Thunder
