L
lightening800
as it says me and deaner installed arts heads on our xps and now we find that the peak power of the sled is now at 78-7900rpm instead of 8200. now fron experience larger squish bands and higher compression ratios usually slow down motors but didnt think it did this to the 800. it isnt a bad thing because i had to add weight to the pins to find the sweet spot before the rpm started to drop and it pulls like hell there, if it want to rev at 7800 and make power there so be it the engine will just last longer.lol. and if your going to ask all kind of questions how i know this here are some of the tests we did to determin this, we swapped ecu did not change, swapped primary clutches and deaner is running the 413 ramps and would not go above 7900, clickered up lost rpm and speed, tried stock exhaust no change, tried different primary springs same 7900 hits wall, only reason i come to this conclusion is i tried to pull alll the weight out of the pins and it still would not rev over 7900 and would start the pipe ringing sound, so i said f it and and started weighting it up after a couple of tries it took about 2 grams in each pin and then the rpm started to slightly drop 50 rpm, and at 7800ish it pulls real hard no bull, so this is where it stays. also it has all stock clutching except heavier pins.
