Is there any way to test the injectors? With a volt meter or anything like that? Also heard of the wires at the injector breaking, how the hell do I get the short piece of wiring off the injector?!?! My sled is only running on one cylinder when cold and I think it starts firing on both as it warms up but bogs as soon as you put it under load.
Here's what I've checked:
Compression is good on both sides
Fuel pressure is good
Has spark on both sides
Checked the reeds and they're good
No cracks in the intake boots
Checked and reset tps
Tried different plugs
If it makes any difference, It has slp can, pipe and head, as well as the re-flashed ecu.
When its running on one If I pull the PTO side plug wire it continues to run the same which leads me to believe the PTO side injector is not firing. And if that's not it I'm completely out of ideas.. Also not the wiring as I have another wiring harness as a spare and tried it with no difference.
Anyone got any ideas??
