F
I think the relay are 05 only!!!
I moved this from another post so I didnt hyjack it!
The Chassis Power Capacitor, a 28000uF capacitor is mounted next to the ECU in front of the fuel tank tank on the 2005 -2006 Cfi's. (it is riveted to the bracket) and is located on the beltguard, under the cover mounted to the regualtor on the 2007 - 2009 RMK's. #3 in the pic at the bottom. can have problems and cause fuel pressure fluctions as well as ECU issues that are related to power. Part # is 4011114 and was used on all CFI sleds from 2005 thru present.
I've also had a bad chassis power-up relay cause starting problems... stuck in the closed positon that caused problems. This allowed the little bit of power that was produced by the stator to bleed off thru the headlights and not allow it to start.
On all CFI sleds, remove the nut to the ground wire on the chasis each season clean the ring terminals with a scotch brite pad as well as the stud/chassis location and put re-install using electrial grease (commonly sold on the lightbulb section of your autoparts store). The Ground point on the chassis is crucial for proper operation of the engine.
Also, on All the CFI sleds, you should keep a spare chassis power relay zip tied under the hood in case that goes on you... Plus, if you ride with Doo guys, you'll be the hero when the lights and gauges stop working on thier sleds.
The symptoms of a bad chassis power relay are lights,handwarmer, instrument etc not working at all or flickering.
You can get a better than Polaris quality relay at Napa for about $15....Napa part # AR274
Location of Chassis Power Capicitor on 2005-2006 900/700 CFI sleds
I developed a problem something like this on the way back to the rig today, I'm wondering if I could have a bad ground or relay possibly, looking for ideas.
Symptoms are:
at idle - low beam
headlights are dim,
leave handwarmers on and voltage display on guage reads minimal power, readout flashes the battery light
high beam
headlights are dim, guage cluster went dead, will come back on if idle is elevated slightly, battery light will be flashing
riding the sled:
the sled runs perfectly, voltage readout shows approximately 3/4 of max, all guages, handwarmers and headlights work normal. Coming to a stop with the headlghts on low and the hand warmers on, the headlights slowly go dim, the voltage readout slowly drops down to 1 bar and then starts flashing, when switched to hgh-beam the guage goes dead and headlights are dim.
I'm not really sure where to start, the sled still runs awesome, idle and reverse are completely un-affected, ther just seems to not be enough power at idle to run all the accessories as normal.
The stator was new at the beginning of the season (550 miles ago)
Chassis ground appeared tight but I have not done a thorough inspection as it was getting dark at the snow park.
Does the motor itself have a ground strap anywhere or does that little dinky chassis ground service everything?
The only other thing I forgot to mention is that if I turn the hand and thumbwarmer off and leave it on low beam the readout will climb back up to half power and hold at that level... headlights will still be dim, but not quite as bad.
okay....Third trip with my 2010 dragon. While trail riding at night my Headlight went dim and MFD went out, and was told my brake light was inop. Would shut off the sled and restart and would be fine for a few minutes, however no loss in engine performance or check engine light. However earlier that day I noticed the left handle grip was approx 1/4in off so I twisted and slid it back on. I will swap relays with the napa and do a brief wiring check and recheck. If problem exists dissconnect grip heater per DiamondDave. Any and ALL info is very appericiated. Thank you to all for the info..... BBBRRRRRRRRRRAAAAPPPPPPP..........
