Ramp change is a must other wise a spring straight from the heavens won't work.
Throttle Junkie, 09 or 08? (What helix does your set up use?) On short break-in ride, my 09 secondary ran hotter with the yellow spring. 80 degrees primary, 170 secondary. Stock spring - 90 primary, 140 secondary.
07, 08, and 09. Tried different helixes, primary weight etc. No matter what way you try to flip it more heat. Gave it a shot but highly dissapointed!
Throttle Junkie, Sorry, I did not post the rest of my clutch set up. Primary spring is stock, ramps are 433's, 22 grams pin weight. Stock secondary
