Indy 550 Throttle flipper 2014 vs 2020
cateye5312
I need an Indy 550 throttle flipper for my Evo - I have a 2014 but it's a different part number than a 2020. Does anyone know what the difference might be? The 2014 and 2020 are both still in the Pro chassis and the engine appears to still be the same so I don't know what may have changed. I suspect it is the distance that the throttle flipper can physically pull the throttle cable. If the 2014 has less travel than the 2020 then I'm okay but if it has more that might create a problem. (fyi - the EVO throttle flipper limits the sled by only being able to open the throttles part way - the upgrade features a full throttle flipper with a 2020 Indy 550 part number)
Anyway, does anyone know what the difference between the two years may be?
In answer to my own question now that I've had a chance to look at a 2020 - the wire loom is different - old style was a smooth plastic covering, new style has a woven plastic loom. The length of pull on the old style appears to be about 1/16th of an inch more (if any) than the new one. I put the old one on and I can't feel the carbs bottoming out or anything so I'm just gonna run with it.
