O
outlawfish
New member
Out yesterday for a good ride. 09 dragon 800 163. SLP single, blue pink with stock weights, carls helix set on the 60-42 with stock spring.
we ride in on the trail, take a good pull at approx 4000 feet and it will pull 8150, do a couple long pulls and it will then hit 8350 -8400 and feel like it is going to pull your arms out.
ride a ways on the trail to another bowl and does the dame thing till it has had a hard pull.
I notice also that it idles better once it has been run hard as well (1750). It hs at times when trail ridden idels down to 1250.
Is it just loading up or what do you think it may be? I had as AKSnowrider has the MTX weights in with the 2 gram in tip, 1 in center and did the same.
ideas, thoughts?
ideas, thoughts?
