P
pura vida
has anyone developed inconsistent rpm when pulling longer hills? spikes up to where it should but then tends to fall off to as low as 7600, most of the time. some times is pulls good rpm for the length of the hill. if the hill is chewed up some and i have to be in and out of the throttle the rpms usually stays good. on one hill the rpms fell off so far the motor fell on it's face (7400 ish), i blipped the throttle to bring it back and it jumped back up to 8200. this is a fairly recent development, earlier in the year is was pulling like a raped ape all hill, every hill.
lets assuming it isn't a clutching setup issue (b/c it isn't). clutches are clean, all rollers are working properly and the bushings are still in decent shape. i cleaned the power valves. it has a new/good belt on it. checked the plug caps, they are ok but want get better ones (see next post), plugs seem/look fine.
suggestions? tps? injectors? clutch is in worse shape than is seems? umm....?
thanks
pv
thanks
pv
