07 M1000 starts up runs great but if you turn anything on, thumb warmer, handel bar warmer, high beam headlight, reverse, hit the brake, thats when it begins. Then the gauge goes dead headlight goes off, and engine idles down. No specific combination either. It does not die just drops down around 1300 rpm. You can work the throttle and it will rev up run just fine and guage will go through the same flashing and what not that it does when you start it up. It will also do this when it is sitting there ideling. Just looking for ideas where to start on trouble shooting this POS, any thoughts would be great.
