![l_98fb4a6a2e454a30a8b3fe552e2288af.jpg](http://c4.ac-images.myspacecdn.com/images02/30/l_98fb4a6a2e454a30a8b3fe552e2288af.jpg)
Got my sled torn apart and noticed some cracks developing on my rails. there is a total of 6 cracks. longest one is about 6mm. where is a goood place to get these cracks welded up before they grow anymore?
just a heads up.. if u r welding on those rails the heat needed to produce the weld is going to weaken the rails around the weld.. your best bet if cost is no option is new rails ...if cost is the option
then find a rail brace from a race sled or whatever is available and bolt it on...
you willbe pissed if u break a rail out in the sticks.. ask around there ar plenty of guys with different opinions but think about worst case senerios. if u jump or pound the trail then bolting on a brace is your best bet.
amds should have brace kits in stock, only problem is it is more for the center of the rail but what you do is drill your own holes so you can move it any where you want. (six bolts per brace) i think i paid like $50 last year. weld is a very bad idea unless you want a new set of rails.Talked with Alaska Weld and he said it is not a good idea to weld as it will be brittle like many of you have said. He suggested to just get some stainless steel brackets and bolt them on and watch the cracks to make sure they dont grow anymore.
thanks for all the info. Is there any aftermarket rail supports for M7's?
