Your going to love it! I had to turn my boost controller completely off so I was only about 14 psi to keep rpms where they use to be running 20 psi on my other motor. Just as impressive is the throttle response. Everyone (including myself) always thinks their sled is responsive, and has little to no lag. Its night and day with the stroker if one is honest. I haven't even turned the boost up past the wastegate setting. Did you do cams/oversized valves/porting as well?
just don't see what the point of spending all that money just to turn the boost down ? wouldn't you have to buy some clutches to use all that power as well ?
Hi what kind of turbo are you using?do you got video when you ride the stroker and som photos of the head and closed deck?Your going to love it! I had to turn my boost controller completely off so I was only about 14 psi to keep rpms where they use to be running 20 psi on my other motor. Just as impressive is the throttle response. Everyone (including myself) always thinks their sled is responsive, and has little to no lag. Its night and day with the stroker if one is honest. I haven't even turned the boost up past the wastegate setting. Did you do cams/oversized valves/porting as well?
I don't plan on keeping my boost as low as it was. Ill probably end up around 17-18. You don't need a aftermarket clutch unless your running a lot of weight in the primary and a lot of rpm's. Usually your rev limiter is going to keep you safe. Once you start bumping up the boost/primary weight/rpm's your looking for trouble.
Sorry I actually don't have any vid of the stroker yet. Lack of snow last year I only rode a few times.
can you pm me your clutch setup, would like to try itYes. For now...
Hotmail,have you find out what timing you are going to use?
Stm clutches and autronic sm4 ecu
Just bought a 1155 stroker from Paul, have anyone tryed this against a stock turboed sled? Any videoes ,photos?please tell me about your expearience is it relyable?Cant wait to try it.He gives great service
