So I am having issues with my 2000 700MM it only idles on the center cylinder. The PTO only build a little heat and the MAG is ice cold. After idling for a few minutes they the two cylinders are flooded. I went completely through the carbs, needle valves, choke, pilot system everything thing is working fine. I have 135psi of compression in all thress cylinders. I even switched the carbs around and the same thing happens. The spark does look pretty weak. Any idea what the problem is? I am fresh out of ideas.
