idle to low
Lately when i start my sled it has been idling around 1200-1400. It almost sounds like the engine is gonna stall on me and i have to hit the gas. Once i ride it for awhile it seems better staying around 1600-1800 then when i stop for 5-10minutes same thing it idles low again until i ride for a bit. Any suggestions? Its a 2012 rmk assault with 2200miles stock.
I have a 2013 Pro RMK, it was doing the same thing, finally to it to dealer and they ended up putting a new TPS and Injectors , the sled has run better then as for a long time. it had 1200 miles on at the time, I now have close to 1400 miles, this last weekend I notice that it wants to idle a little slower again, not has bad as before, BUT ???????????? At the time it was worked on it had 115lb compression on both sides at 1400 ft elevation, that was with an older gauge, oil pump has been turned up from day one, valves are clean, everything checked out good.
I started my sled up today in my heated shop and it idled just fine it only seems to do it when i trailer somewhere and it gets cold or when im riding and stop for a 20minutes or so it does it. I really hope i can avoid going to the dealer.
