My Stock rails are bent where the front torque arm connect to the rails. Are the iceage rails stronger? I hit decent jumps, and some landings are rough and hard. Some feedback would be great
I think I may know how this happened!
Strengthen your stock or IceAge rails with the IceAge billet X-Brace. Provides increased torsional strength that far exceeds that of cross shafts or rail stiffners. Designed to mount between the rear suspension torque arm and rear idler wheels or between the front and rear torque arms.Applicable to all stock and IceAge rails.
I believe that for those that ride hard... a couple more cross shafts will go a long way to keeping the rails from bending.
Once the rail "bows" out a bit...even the bomber rails... it's toast! The cross shafts keep that from happening.
First they bow out.. then they bend... then you buy new ones.
Cross braces And/Or rail reinforcements will help keep that from happening.
http://www.iceageperformance.com/pr...shafts/snowmobile-slide-rail-cross-shaft.html
Ice age has a new X-Brace that works real well at keeping things locked down though it may collect some ice... Paint it!
http://www.iceageperformance.com/products/lightweight-accessories/cross-shafts/iceage-x-brace.html#
I ordered an extra cross shaft and bolts as preventative measure for my Pro. It looks like all of the bent rails I have seen are bent or bowed out between the rear scissor mount to the rails, and the front torque arm mount to the rails. Question: I have holes in my rails for accessory bogies behind the front torque arm. The upper hole looks like a poor choice as the pull rod will contact a shaft installed there. How about the lower hole in the rails, do you know if the pull rod will move into that position at full compression?
