I need some Summer Tuning Tips
SixtySevenGT
So I am the one who had no VES springs. Put Yellow in because I had them.
The White SLP version seems to be lighter I will get those.
I noticed carbon buildup on the roof of the Ports, I will most likely do the Top End even if just to put in rings and clean things up.
I bought it last fall with about 300 miles on the motor. I put 1000 on it trouble free.
It has the freaking loud CPI stinger on it, Should I keep that or put and SLP on it?
I like it becasue it pi ss es off the Cat and Doo riders.
I really wonder how much back pressure it gives, may be some of the power band issues. I know the VES springs (putting some in ) flattened out the band
considerable amount. It would stutter to about 7500 then hold on for dear life.
It would run hard at 8100 -8200. With VES springs in at least I have some smoother power come in at about 5000. It runs much better cold also. It always idled good.
I will put a new clutch bolt in.
I need anti ratchets, I got the track very tight to quit the Ratchet issue.
I will do the 09 Plastic and bumper
Just put in a new Pull rope.
05 900 RMK IQ
HRP EZ-Steer Spindles
Ryde FX Shocks
2009 Dragon Gripper Skis
166 Track
Ported Track
225 lb Carl’s Front Spring
.405 Rear Springs
New Primary
Gearing
4 inch PowerMadd Pivot riser
Lefty Throttle
Better Boards
Scratchers
SLP Pipe
CPI Stinger / Can
Fire N Ice Intake
SLP Flow Rites
SLP Head
Carls Porting
New Pistons
V-Force 3 Reeds
32mm Crank Upgrade
On the Trail to Pilots Peak in Idaho April 3rd.
It was a great year for Me / Glad I bought a 900.
( note the Doo in the fore ground , good for towing practice):face-icon-small-coo
05 900 RMK IQ
Ryde FX Shocks
166 Track
Ported Track
.405 Rear Springs
New Primary
Gearing
Lefty Throttle
Better Boards
Scratchers
SLP Pipe
CPI Stinger / Can
Fire N Ice Intake
SLP Flow Rites
SLP Head
Carls Porting
New Pistons
V-Force 3 Reeds
32mm Crank Upgrade
A couple thoughts...
If it is infact "freaking loud" throw the SLP on there... other sledders will like you a lot better... and may help save a riding area;):beer;
8100-8200 RPM :eek: Why are you spinning so fast? Even with the SLP pipe you should only be spinning 7800 RPM... Do any of the other mods recommend spinning it up faster?
Ratcheting... ya my buddy ported his 166 and has had to tighten it a LOT to prevent ratcheting... and he still gets the odd slip every once in a while... anti-ratchets may be a good idea.
New clutch bolt.... sounds like a good idea to me... ;):eek:
I also love my 900, also very glad I bought it.:D:D
Tip #1: Trim the dirty Sanchez, you'll have less snot/ice buildup!
If you live in Colorado, you might run into problems with a loud sled this next winter. Colorado will be enforcing noise ordinances for sleds.
