I am reaching out for some insight and help. I have the Axys 163 2.6 ride at 8000-11000. I cannot get rpm above 8100 on a hill and about 8200 maybe 8300 on the road.
I have changed spark plugs. Put in a black green primary spring, stock helix, tried both black purple and black white secondary springs. Ran 62 Polaris weights 68 MTX no weight and then 1 gram I'm the tip. This years MDS weights. All different combos. And the RPM is the same. In all set ups. Pull a hill 8000-8100. Down the road 8200 if it's just right 8250. Track speed up a hill max so far 34mph. The primary appears to be shifting all the way out. I have drawn line with black marker to make sure I am getting full range of motion both primary and secondary. I put on the jaws pipe no change of RPM. It sounds like the power valves are working you can almost hear it with the pipe 6300 and 7300RPM.
I have called local dealers and they can't say what it is. Could it be TPS? One dealer said there was a "canister looking apiece about 2 1/2 long above the oil tank that has about 5 wires in it that shorted on one sled and that caused low RPM and Polaris was back ordered for that part. But all dealers just said well 8150 is where Polaris says it should be and there is no lights/codes showing on your end. Trying to figure this out. I need some other thoughts as I have exhausted my limited knowledge on it.
Any thoughts as what I can look for or do would be very appreciated.
Thanks
Chad
Thanks
Chad
