I need help removing sway bar on Nytro Mtx
otis
I am in the process of removing my sway bar and have decided I don't want to fight removing the bushing/brackets holding it on.
Many others have had to cut them off and I am at that point too.
My question is if I cut one side can I hammer it out the other side? There seem to be a couple of bushings pressed on the inside of the brackets. If I just cut one side can I push it through the other side? Will these "bushings" slide off if I hit the sway bar through to the other side?
Thanks
Otis
Cut it right in the middle. Each side should slide out easily.
Or, you can heat the bolts in the brackets with a propane plumbing torch. They come out alot easier that way.
If i'm too lazy to take the bottom plate off and cut the middle can I cut one side and hammer it out the other side? Has anyone done it to confirm it will work? If I go through the work of taking it all apart then I agree I should just heat the bolts and take it off.
Otis
