Hydraulic Guru's
To add a loader attachment to a tractor with aux rear hydraulics do I need to run a power beyond type setup or can I just t into pressure line to rear of tractor? Thanks for any insight into this.
There may already be Ports on you tractor somewhere to add the "juice" to your loader.
Make sure hyd PSI on tractor does not exceed what they system on the loader is rated for.( I folded a hydralic thump up like a pretzel once because of this.
It would be best if you found what others with the same set have done that worked (should be something somewhere on the net!!!!)
seems to me it would be ok to ty in directly from the remotes or behind them
but there is usually some other ports for a loader on many tractors I would look around a bit before you start splicing.
BTW
if you multiply your gallons per minute by your pump psi and divide by 1714 you will get your aprox HP of your hydralic system ( nice thing to know in certain apps.
good luck
DOC:beer;
