B
burf91
New member
Sled was running fine and up and quite. Pulls over with no spark. Started checking wires, grounds etc and all looks ok. Just trying to check the stator. Does anyone know for sure how to check the stator/coil charge assembly. I think I have checked it right but just want to make sure. I am checking the resistance at the 3 wire connector near the recoil. Have checked the charge coil #1 circuit(black/red and green/red wires) and found OPEN. Checked charge coil #2 circuit(brown/white and green/red wires) and had resistance of 8 ohms which I believe is ok. So I am suspecting charge coil #1 is my concern with it being OPEN? Anyone else run into the same concerns? Also have read that you can get the stators rebuilt? Any around Alberta do that?? Thanks in advance.
