How to shine up aluminum parts??
Circus Midget
I've got my sled all tore down for an engine rebuild and I want to clean it up. What's the best way to clean and brighten aluminum parts that are a couple years old and starting to dull? I'd like to clean the clutch up since it's got some oxidation and the crank and cylinder have some oil/belt dust build up.
Also, anyone know of a good place to buy head and cylinder bolts for a Doo?
Checked today and they told me $8 a piece for the cylinder bolts.
Buy your bolts at ACE.
Do you want to SHINE/Polish your aluminum parts or clean them up?
To clean them up I just use brake clean.
To shine, I start with sandpaper working my way up to finer sandpaper and then finally use a good aluminum polish. I just picked up some Mothers that worked good.
For the engine parts and clutch we use easy off oven cleaner and a preasure washer, to polish, mothers wax, and some multipurpose cooking flower. my.02$
I use mother's, 3-M, or Turtle Wax. Since you are asking for suggestions, if you have a good cordless drill, get the mother's Powerball. It is nice in a lot of areas and cuts down on a lot of time making circles.
I used a polish called white diamond aluminum polish and that has worked the best for me. I also used the mother's powerball with it and together it's a little messy, but the shine is well worth it! Mother's is good as well.
if you want to just clean them real well and brighten the aluminum back to a bright whitish color, theres stuff like what we use at work called "Alumabright" you might be able to find something similar to this near if there is any semi-truck washes around your area. it cleans aluminum great but its an acid so you gotta be a bit careful with it it will eat clothes and can cause some skin irritation so i would recomend gloves if you try it.
clean -up
On cast aluminum parts like jugs and cases I use a product called Alumi-blast from a company called Seymore... It makes stained or corroded cast aluminum look like new, and stays that way!
