That connector is way too small!
Get a couple of the charging plugs too.. One to splice into your sled... the other to charge the pack with a 1 amp or less trickle charger..
We think we might have a bad fuel pump on a sled that we had to leave on the hill. Would trying to prime the fuel pump be an easy way to figure out if the fuel pump works? There's no fuel pressure so any help would be great!
Ok, the connector on the 900's .... can you access this with the fuel tank mounted or do you have to remove the fuel tank?
I can't figure out where this connector even is ....
ok i did a turbo install on my 07 d7 and i got it all in and trying to start my sled, and it wont have non of it, i tried that priming the system thing and well that seems to not work, the pump comes on but it wont start, was wondering when you take the cap off for the bleed off if it should spray gas without being pressed cause mine is, is it probable that i mixed the gas tank up when putting it in the sled and the lines are backfeeding? i havent found anything on the internet about it. anyone have any suggestions
prolly a silly question but could I use a battery charger that has a 12 volt @ 2 amps.? Or would a car battery work, don't have a 12 volt pack.
thanx in advance!
Redd
