how to check motor mounts?
Im just wondering how to check the motor mounts on my 2012 rmk assault. It feels like when i grab the primary and pull up and down there seems to be a bit of movement. How much movement should there be if any. I went through 3 belts in 600 miles. Any other reason i would chew through that many belts, maybe something wrong with the clutches? Thanks in advance for any info.
Just losen the bolt off and then pry the mount out with something like a screwdriver or pick. They are relatively easy to remove with the right tools no need to pull the engine to check or change mounts on the Pro
