How the hell do you remove the skid? Those damn axles with the bolts on each end so that when you get one off the other just spins. Whats the secret to getting the other bolt off?
Impact is nice...run the first bolt in and out a couple times to soften the loctite....same with the other side, then you have a better chance of getting them out without spinning the shaft.
Or get a longer bolt of the same thread and put a nut on it. Take out one bolt and put the longer bolt in, tighten jam nut....then remove other bolt, loosen jam nut and you can spin out the long bolt....if that makes any sense.![]()
Also use ratchet straps to pull the front and rear arm down.
It'll make it easier to come out
