A
Anthony Oberti
How much you guys running with the new head at 12-13lbs? And at which point do you have to run straight?
i have 09 d8 with 2010 updated head and i run 14 psi at 7000ft and i use 50/50 c12 and pump, never had a problem
Wow!!!! I have be running straight 110!! Guess I wasted alot of money...o'well,
i ride 6-9k feet... and run up to 13lbs with just 2 gallons of 110 motor octane race gas to 13.5 gallons of pump... its worked great so far... 1200 miles and counting this season
how many plugs have you changed???????LOL![]()
Easy there SPORT. Wasn't trying to get you all hostilemy sled is a pump gas turbo buddy... running 2-3 gallons of race gas is a little extra assurance because all of our pump fuel is chitty around here and full of ethanol. i have ran this set up for over 5 thousand miles with no blow ups or burn downs, so it obviously works. there is no ratio... i just do it to be a little more on the safe side. my egt's are never over 1290, and my charge temps are never over 200
Times two, especially the part about "error on the safe side".Yes, you are correct. The motor will run best at the optimum ratio of race fuel to pump fuel. Best to error on the safe side.
