I am wondering how the ignition timing on the current 800 RMK works. I've read a lot on the forums about higher compression heads, different pistons and other performance modifications. I want to know how the ignition timing is controlled.
Is it controlled off of engine RPM and throttle position only? Or are there other parameters that are read by the ECU? Such as outside air temperature barometric pressure? Since there's no O2 sensor I assume that this is an open loop system?
Does the timing need to be advanced or retarded to get the most performance out of a high compression head or different pistons?
