yeah, i know it wasnt a ton, but even 2 amps is a decent little chunk of your already dwindling supply!Chris told me the controller pulls 4watts during warmup and 2watts after. Not a lot of draw but something to consider.
Just a question, has anyone ever tried the heated gloves. Seems like some well made heated glove liners would be a hot item in the sno world. I would even take them snow boarding, just throw a lithium ion in the camel back and go all day. Might have to look into some.
I was told by Rick's motorsport electrics that there isn't enough room to add any copper to a '13 KTM 450 SXF stator - but I found a place that says otherwise and their high output stators should be available soon.
One precaution I took is to install a bigger battery. This should provide reserve power for starting, allow a bit more reserve power for hand warmer startup and to give any extra current a place to go under higher RPM (in theory).
I also plan on monitoring the voltage - the last thing I want to do is end up in the boonies replacing a stator!
is it not like before where you could just take the xc stator and flywheel to do the job. I think 07 or something you could do this.
And I assume all of the electric FI bikes use a single pole and the battery to power everything correct?
Daryl can I use these grips your getting on my rmz?
So what's the verdict, Are these kits available yet? I would like to order the complete set.
Turkey day got in the way, it looks like they will ship on Tuesday, We will try to have them on our site by early next week.
There will be two options, One for bikes with batteries and another special kit for EFI bikes.
Ok, I'll bite. What's different about EFI bikes that requires a different heated grip setup?
