How did this even work
T
theUltamateTBM
so tonight I was working on a friends gen II 700 with slp twins he was complaining about no bottom end so I pulled his primary clutch apart and found a dark blue white primary spring 120-310 with a straight 10 weight that is 50 grams the secondary is stock this sled is way super fast on the top but his tack has never worked so I assume he was spinning super high rpms my old 700 I ran a polaris black that was 140 330 and 10-62 weight and it pulled 8100 rpm how did his sled work so good
My kids 700 has that spring and 10-58's. Turns about 8thou. PSI single pipe.
Are they polaris 10-series weights or comet 10's
If they are polaris weights that thing would be spinning about 9k. Depends on his secondary setup a bit too though.
