Anyone use a hot dogger with twin pipes? Does this cause a tuning issue? Should I run two hot doggers?
i use one on my slp twins, no problem. However, if you have mooching hotdoggerless friends you may want to run twin hotdoggers.
thanks!! I was wondering if a single hd with the twin pipes would screw up the jetting. If i install a digitron egt, does it have settings to compensate for the single or twin hot dogger system on twin crank shop pipes??? Can i put an extra egt inside the hot dogger so i know when it's all at 425f???
A dash mounted overheat beeper for your lunch would be cool!!
I find that when I put my hotdog, In between the twins its a messy situation.
