M
mngoat
got a small snobunje battery i'm going to run a small acc. off of....battery has a wiring harness but just wondering where is a good spot to connect charging wire to? 2012 electronics...i see a red,yellow and brown wire coming of voltage regulator...this plugs into main wiring harness....yellow wire goes directly to stator...brown goes into brown/ground in the harness...the red turns into a red/green wire in the harness...looks like this red/green wire runs up to another connector that im assuming is for e start harness....like i said looking to see what i can tape into to charge the battery...also do i connect the neg side of the battery to chassis ground?? Thankyou
