Shock to track clearance is the same throughout the suspension cycle.Summ8rmk, can you get measurements of the rear Alpha arm? The upper Alpha arm looks shorter than the twin rail design? Also are the bolt ctr's closer together on the lower swing hangers? I am in the process of making an on ctr design. The bottom of the shocks will not rub, but the top is my concern! Does the top of ea. shock rub in static, or when suspension starts to compress matter get worse? I have made my clips, will probably adjust height down on the ctr. guide if needed (.440 tall presently) Thanks, any info would be appreciated Mike
The top rear is an easy fix, run the rear axle wheels off an Mseries, that will allow clearance. The front shock, not so easy but still not to hard. Just move it right or left 1.25".
Polaris [emoji2955]
