A
Adrenaline Revolution
These are all good ideas but jeeze...
I don't want it to weight a TON!
I'm thinking saving weight by not even having a plywood deck. Just use cross supports under some plastic ski guides. And more spaced cross bars for where the track sits. Almost like continuing the ramp. If the ramp can take the jaring of a sled riding up it. Then the same building technique should work for the deck.
These are my thoughts.
This would eliminate the slippery, wet and Heavy plywood deck.
I thought about trying to build one and I was concidering doing the same thing.
One problem is that you'll wish you had a solid deck when/if you want to put covers on or just getting on or off your sled when it's up there.
Plus a deck gives you a place to stash covers and other stuff underneath, out of sight. With just rails all the snow, ice, mud will end up down in the bed on whatever is under there.
just my .0197
