Hijacker 2.0 + Pump gas + 6000-8000' = #lbs boost?
I thought 12 was stock at sea level? If you were showing 9.6 to 12 at altitiude you were way underboosted. Stock at 6000 ft would be putting out 15 psi if you wanted to target 15 sea level you'd need to set 18 at 6000 ft.
I believe my melted boost reference line may have been leaking some pressure that's why I had the lower pressure.
I was kind of worried about that too, the reference line they gave me is too short to follow the wiring harness I might try to find a longer piece so it can be tied to the HJ harness.
Yeah after that I ran mine down to the factory boost sensor, along the clutch cover the up along the boon docker wire harness. I rolled the sled over several times, rode the piss out of it for two days and not another single issue.
To find out how much boost you can run turn it up slowly until the det sensor goes off then back down 2-3psi.
