P
Hey everyone I'm working through a problem on a new to me 2008 Dragon 700 RMK high (3200RPM) idle issue . I'm thinking vacuum leak so this is what I've done for trouble shooting and just maintenance:
- new intake boot
- cleaned throttle body
- cleaned/rebuilt power valve
- o- rings on injectors
- cleaned and inspected reeds
Started it up........3200rpm's after a bit engine code 5 for exhaust temp comes on. It's for running above 3k rpm's for longer than 2 minutes, etc etc etc. Can't imagine that would have anything to do with cause of high idle.
So back to trouble shooting:
- sprayed throttle/ brake cleaner around engine expecting if their was a vacuum leak it would pull it in and raise the rpm's. That did not happen..... so no vacuum leak??
- I'm about to check out my TPS. Been on YouTube for videos and have a fair knowledge through YouTube university.
- I also read a review that the ECU was damaged done how. I have a 2009 800 dragon, if plugs match up do you think theirs any harm swapping the computer into the 700?
Thx any advice would be great, TIA.
I did notice the coolant temp sensor was not at the desired resistance. Desired 2.5k-ish ohms @ 68°f and mine was at 4+k ohms @ 54°f. I'm assuming that would show it to be extremely cold and then would it ever show it to be warm? Don't know.
I also checked my spark plugs, they are not showing a lean issue situation at all. However I'm only running for maybe 1-2 minutes each time.
I have nearly gone through a can of brake clean testing for vacuum leaks and nothing found.
Any advice greatly appreciated.
![20211007_181018.jpg 20211007_181018.jpg](https://www.snowest.com/forum/data/attachments/322/322312-0336005f0f1b49029f5de2b5ba89cebb.jpg)
- new intake boot
Okay I'm back with even more dead ends. I went through my TPS and came up swinging. I first tested the current setting, it was with in .002vdc so I almost didn't move forward. I decided to go ahead with my TPS testing. I first started with a baseline, I backed off my throttle cable and then my throttle stop. The TPS was sitting at .687vdc so it was off. I adjusted to .700 on the dot by rotating the TPS itself and locking it down. I then brought the idle set to .950vdc on the dot. I knew I had this licked. Put everything back together and pulled the rope. Boom.....right back up to 3200 rpm's. Crap I fixed nothing, again.....I did notice the coolant temp sensor was not at the desired resistance. Desired 2.5k-ish ohms @ 68°f and mine was at 4+k ohms @ 54°f. I'm assuming that would show it to be extremely cold and then would it ever show it to be warm? Don't know.
![20211007_144928.jpg 20211007_144928.jpg](https://www.snowest.com/forum/data/attachments/322/322311-b39e64409dd2571b5899db202be7567d.jpg)
