Its more than likely a rich condition. Does it sound like its miss firing, and feel like it just hits a wall? Here are some pointers for you.
Change you plugs, or at least gap them down to around .020
Lower your High Psi fuel number a few numbers.
Watch your wideband gauge if you have one, Slowly bring your rpms while riding and watch that gauge closely, the numbers will probally start going like 14 13 12 11 10.9 10.8 10.7 and then instantly spike to like 18 or a high number, You are probally blasting off way to fast to WOT and dont look at the gauge until its starts to misfire or flood out, And they will always read LEAN when it misfires and floods out.
Also a leak in the charge system can cause your sled to do similar things, Check all your clamps, boots and fittings for leaks.
And too much octane will cause a sled to act this way also. What are you running for fuel? Elevation?
Send me some more information on your setup and I will gladly help you out.
Thanks
Justin Silbernagel
