G
Gobig510
On my 2008 M8 Race Gas Turbo running 13+Lbs of boost I can't seem to get the track tight enough to keep it from skipping under high boost and high load. I have the track so tight I can barely spin it with my hand when on the stand. If I WOT on the trail it won't skip, even about 3/4 throttle in deep snow up a hill it won't. It only happens when I'm WOT in deep snow pulling a hill. It just started doing it so I tightened up the track a little bit. It continued skipping so I kept tightening the track but now the track is tight as hell and hasn't solved the problem. Looked at the track drivers and they look fine and seem to be in the track groves fine when on the stand. What could be happening?? Its really annoying that I have a sled that has the power to climb anything but I can only climb about as high as a stock sled then the skipping begins!!!!
