whats the turbo for? 2 stroke? 4?, i noticed it says its a wet float bearing, unless your pumping like 40PSI oil pressure to it... it wont work
The 2860 sled no doubt has better aerodynamics inside the turbo, it builds boost lightning fast as soon as it gets spooled up. The 82mm pulls way better out of the gate only because it does not violently bust the track loose like the garrett. Pound for pound I think the 82mm is going to have the edge, it has a water to air system, I needed a edge over my buddies sled.
I love Polaris pro platform, as far as cranking up the boost is not going to set any records, that motors foot pint is just to small and light. The 2011, 2012 would be my choice. Polaris is tiring to keep emission down so that don't want to feed the thing much oil, doing so the piston are loose .006 on a cast piston. Boosting it helps the logevety of this motor (7 psi not 17) I have seen 2010s that were .012
There are a few guys building long rod motors you might look into that.
I do not know what your going to do, and I don’t know were you ride were you use the kind of boost you do, it's puzzlig to me
Wow... You get what you pay for. Do I wish or think the garrets could be cheaper? sure. If you look around or have a good hookup on turbos definatly helps. But a really good turbo is going to cost a lot more money then a cheap Chinese turbo. Huge difference in research and development, design, machining quality, clearances, balancing, and materials used.
More power too you for trying something different. I am sure if you bought, tested, and tried several different manufacturers of the cheap turbos you could find one that is decent and a lot cheaper then a high dollar turbo. I don't like putting un proven parts on my stuff, don't want the risk of something failing, or less performance. I know of a guy that sells high dollar turbo's and builds some pretty badass turbo systems. He buys a certain Chinese turbo, re machines it, and puts a garret ball bearing center section in it. when he is done it is a good turbo, but it took him a lot of R&D to save a few $$$ on his turbo builds.
Has anyone tried Mitsu turbo's?
I've read of 4 stroke sleds having the oil line blow off and guys doing a few pulls before noticing and the turbo was fine.
I see them come up used for as cheap as any ebay turbo's and they seem cheap & easy to rebuild.
They say it's a really well designed journal bearing turbo, some say better than Garrett.
They are like mopeds....
That one will be tough to convince this crowd. My sled engages at 3800 or so and I have boost at that point. By the time I hit 7000 or so, I have 10lbs(if thats what I am running for the day). I have yet to see a Garett do that.
I hope it live on a lot less, we will find out
