help with rt hi alt clutch setup
so i ride the 05 rt 162 and im thinking i dont like my current configuration. i cant remember what it is exactly. and its really not relevent. but it is super unusual and i can guarentee none of you run it. but i wanna know what youre all running for your clutch setups if you dont mind. im running the team tss04 secondary. i ride at 11000 feet in colorado.
1)whats your track speed under load (climbing and in powder)?
2)what alt do you ride at and in what state?
3)whats your track lenght?
4)whats your clutching setup?
thanks
-nick
I'm assuming you're runnin the "BRP high altitude kit" with the 800 aluminum arms and ramps (can't remember the ramps)?? Going from memory when I ran that...19 grams (maxed out?), 44/40 or 44/36 button helix (whichever one isn't stock) 20/49 gears at 3,000-6,000 feet, with a 162 track. Absolutely ripped after the 07 mapping. My dealer tried the team secondary but he felt the stock secondary was a little better on the stock 1000's.
I could never read my odometer but was always runnin a little to high on the rpms and only the Polaris 9 could stay with it. If I had kept it, I'd like to have tried the Dalton 60 gram arms as I feel the aluminum were to light but the stock were to heavy. It was the first clutch set-up that came out for the 1000 in early 05 and it never ate but 1 belt in 1,500 miles (minor wear out in spring snow) but definately could've been improved upon.
I'm sure I was too low of alt for that set-up
Sorry I couldn't be more help.
