Help with pin weight and spring
sledr4life
does anyone have any good set ups for the spring and pin weight for an 02 800 summit? Riding at 8-11k
I was trying the aluminum pins, but keep going through them along with the rollers
sledr,
Go with the stock hollow pins(9.8gr?), 160/260 spring. In the secondary, a helix with a finish around 42 or 44. Can't remember if the 02's had the old formula sec. or the newer HPV. In any case, run Doo's stiffer spring. If it's the old torsion sec., run about 22lbs. This should get you close.
Dave
