Top rpm
Does the glide washers only affect the engagement rpms, and not top rpms?
YES! Blk/Orn are the ones that are breaking. Get the Yellow/White, tad lower engagement (maybe 100rpms) and same finish rate. Get a set of Thunder Products glide washers and install when you replace also. That will put the engagement up 100rpms with the 2 glide washers, they also give you 3 more washers to install in desired which will bump up engagement rpms 50rpms per washer.
