help please..........
i just changed my track out from a 2" to a 2.33" on my 06 rev. i used all the same holes when putting the chassis back to place. i installed new rails also.. now the new track is making some rubbin noices in the front and back when i go up or down a little slope... on the striaght away it is fine... wondering if someone knows why its doing this....
Did you install 9 tooth drivers when you made the switch? If it had a 2" track, it probably had 10 tooth drivers. Count the drivers, you may not have enough clearance.
Oh!!!!Crap!!!
You have to pull the drive shaft back out. Buy 9 tooth drivers from your dealer or tracks USA, press them off with a hydraulic press, press the new ones on and re-install drive shaft.
