J
JedInUtah
Alright here is the deal. Helping a buddy on his edge, not sure what year but its the gray and yellow one. It over heated on him and coolant leaked out. Towed it home.
I poured coolant in to see if it would run out on its own. NO
I then ran it a bit on the stand.....temp light came on. Nothing leaking. Coolant wasn't cycling so figured thermostat. Pulled thermo and ran again. Temp light again, NO Flow.
While still warm I pulled the his on thermo housing. Steam coming out, lots of pressure no coolant squirting though.
Here are my thoughts and need some input.
# 1- water pump not cycling. Can water pumps go bad without affecting engine performance?
# 2-still air in the system not allowing it to circulate?
# 3- I did pull the head and no signs of cylinders burning coolant, that doesn't mean the system isn't getting back pressured.
Thoughts??
Thoughts??
