Help no power to gauge and sled runs at half power
sledsnowco
I have no power to my gauge and it's plugged in and the sled is running like the exhaust valves aren't opening. Looking for water in a connection or something loose with wiring. Any help would be great.
For some reason I want to say the relays out in the open mounted to bulkhead are for the power valves. They have been known to have the pins corrode.
I would double check the hood harness plug in. Even that you say its plugged in, check contacts and how it plugs together. Cuz it sure does sound like hood harness/limp mode.
on the axys chassis having the hood harness unplugged causes limp mode? on the Pro this isnt the case at least not on mine
Thought so, on Dylans 16 ProS Last year, he said he couldn't catch up to us for a stretch. Till we got to intersection and waited for everyone. He thumb down, so his gauges quit on him. That's what we found harness came unplugged. Figured it had been in limp mode, cuz he said it wasn't running right, he couldn't catch us. Was fine after.
Check hood harness plug then the relays on the cross bar of the upper structure.....Mine did this and it was the relays.
Did you get this figured out as of yet? I'm having the same exact symptoms, local dealer has it now and is having trouble getting it figured out as well. He has been replacing parts with a sled off the showroom to no avail. Every electric connection in the sled has been greased since day one, and I went back through them twice after these issues appeared!
Dealer replaced the relays on mine, still no gauge and still has the same symptoms. ��
Happened to me yesterday and my son the day before, fire up the sled with no gauges than a few mins later the gauge works with no intervention
