I have an issue with my sled going into det mode this yr.
Never had problem till now.
Left about a gallon of full in over the summer with stabilizer in it then fresh full to start off season. Stock pro with par13.6 head with two seasons on it with no prior probs. 400 miles total..stock clutching.. over fall I did this,
Changed clutching to mds
Then Indy Dan balanced and sheeve mod done
Then cleaned power valves.look all good just a little carbon
Then swapped exhaust pipe to a brand new 14 because mine had some minor rust and I'm o c d ish, and I had a brand new pipe.
Then last..but,the thing I screwed up was I notice my throttle cable adjuster under the rubber sleeve was loose/lock nut thing was spinning and the short of it is i screwed up my adjustment on cable then on the idle screw.
I took it in to check my det codes and presumably adjust my tps back to were it should be. Lessen learned. ..well
Went and picked up sled from dealer and notice sled now ran from 1600 rpm now to 1900-2000. I took it home, then the next morning drove it right back thinking something wasn't right and asked how they adjusted tps?. They told me it was right and my idle is just the way it is because the ecm??. Ok well, I understand it to be different. I asked/explained how I thought it was supposed to be done by making sure there is slack in cable, then back off idle screw till throttle plates close, then adjust/synce tps then adjust idle.
He in formed me you don't back off idle screw.
I explained it had to be backed off to "zero" out, close throttle plates.
Well I browsed the store and later he came up to me and said he was wrong but the mechanic will check it out again...he also said that mechanic could adjust tps within specs and drop my rpm back down some?.....ok?
Fast forward pick up sled , they dropped rpm to 1800 ish took it up today and runs fine till I load motor then det. Not as bad or sensitive as before but still det.
I am running 110-120 temps.
But if I keep on gas for 3 secs.....det
I've created many variables but still thinking...it's tps this time I noticed the mechanic got into my idle screw because my can was pulled off and tossed around on the floor.so anyway
I am trying to locate someone or way to check it myself since they won't be able to for a week plus...
I rode the 1996 440 z today and it just isn't the same.
Thanks for any help 801419425four. Logan ut.
